Borit have one
  • Borit have one
    Need to bore under a driveway anyone have experience with this? video looks good.
    http://www.borit.com
    Re: Borit have one
    Very interesting, I'll bookmark this for the future, as we have hard clay here.
      Re: Borit have one
      These types of hand drill water hose devices have been around since I been a part of the trade.
      I forget the name it was called in the eighties.Pasco's making money off it for the past decade.
      This one's head looks a little more ergonomic...kindof like...Uhh...
      Oh,never mind.That one has already been previously chosen for thread of the week last week.
        Re: Borit have one
        i have a few of them and even make my own paddle blades.
        the trick is to bore small and aim properly. then ream larger on the pull back.
          Re: Borit have one
          Rick, I remember the awesome blue pipe rack setup You have. Idon't have the $$ for that one. And I just have to get under 1 driveway right now. the whole tit is just under $300 and will be added into the project price. HI PHOEBE
            Re: Borit have one
            I use a different brand called Hydrodrill. The drillng heads are not as advanced as the Bore-it. I watched the Bore-it video and don't care for how they promote it taking 19 minutes to bore a hole under a driveway starting from pulling up in your truck at the jobsite. Not in your life. Most times I drill I am wet and muddy and have had to stop several times to wet vac out the accumulated water in the trench. I nearly always hit a large rock that takes some work to get around. I have drilled through an area drain and have taken out irrigation as well.
            I did manage to drill from the side of a swiiming pool to a 16" x 16" hole in a utility room slab that was 30' away and got it, but was very lucky and wouldn't try it again.
              Re: Borit have one
              Ever use a pressure washer hooked to one ? STERIODS !!
                Re: Borit have one
                What are you trying to do drop the driveway into a steroid sized sinkhole?
                The Kevin I know would have someone tarred and feathered for less.
                  Re: Borit have one
                  I'm not believing for one minute had you been faced with a prettier damsell with the doe eyes in distress you'd be rollin' out a hose before I could even say "Bu .
                    Re: Borit have one
                    HMM, Straight down , WELL ??????????? HOW would You muck it out ? Gas trash pump ?
                      Re: Borit have one
                      a bailer would work to muck it out,
                      a pipe with a one way valve on the bottom of it and a rope to lower it if you have to do many times set up a pulley above the well
                      http://www.fao.org/docrep/x5567e/x5567e05.htm
                      http://www.petroleumhistory.org/OilH...ng/bailer.html
                      page 4 good picture of both a dart and a flat bottom bailer
                      http://140.194.76.129/publications/e...2-1908/a-b.pdf
                      for a shallow well and small casing, a good air compressor will most likely blow it out, drop a line down to the bottom and turn it on,
                      I have a borzit tool but have not used it much, but what I have used it like it,
                        Re: Borit have one
                        Once again, the most clever and industrious of us all " THE AMERICAN FARMER "
                          Re: Borit have one
                          I looked at this one too when I though I was going to be boring a water line under a couple of driveways.
                          Didn't get it though.
                          http://www.borzit.com/
                            Re: Borit have one
                            Stupid question. Why do you even need the water?
                              Re: Borit have one
                              [quote=jcsplumbing;312567]i looked at this one too when i though i was going to be boring a water line under a couple of driveways.
                              http://www.borzit.com/ Thanks JC Have one of these coming 2",3" and 5"
                              I didn't go with boreit , no one to answer phone. Tel tag around 6 times ! BORZIT, GOOD EXPERIENCE, PROFFESIONAL TO TALK TO.
