Bath tub drain
  • Bath tub drain
    The wife wasn't feeling good and decided to take a hot bath. When she tried to flip the stopper, it wouldn't budge. It is the kind where the stopper is internal (no pop up). It has been at least 10 years since anyone has tried to use it--always take showers. Is there any easy way to loosen it or do I have to take the whole thing apart? And no, I don't have access to Plumber Rick's supply of equipment!
    Re: Bath tub drain
    Take the screw out of the overflow and spray about 1/4 can of your favorite penetrating oil in there. Let sit. Then put the screws in and see if works. Doubt it will. Don't force it.
    Might have to take the assembly out and clean/repair/replace.
      Re: Bath tub drain
      Thanks, J.C. I will give it a try.
        Re: Bath tub drain
        10 years without use is the issue. the brass on brass is a problem.
        try vinegar or coke too. if you pull on the linkage and the bucket stays below, then you need a good coat hanger with a hook on the end to try and snare the bucket from the top/ overflow.
        i've had good luck with the micro explorer to hook and position a hanger.
        when you do get it out., sand and polish the brass bucket, then lube it and it should be fine.
          Re: Bath tub drain
          Just an update--Tried all the suggestions-none worked. Next step is take it apart and try to repair or else replace. Thanks again.
            Re: Bath tub drain
            PULL HARDER nothing to lose now
              Re: Bath tub drain
              Using WHITE VINEGAR I managed to get one unstuck. One gallon from Wal-Mart.
              Poured in drain and overflow.
              With each treatment I rapidly tapped the linkage with a small hammer.
              Once out, I thoroughly scraped it with a knife but never oiled it.
              Wanted to use silicon spray but could not find it.
                Re: Bath tub drain
                get a heavy coat hanger or 1/8'' welding rod. take a pliers and bend the last 1'' into a hook with a 1/2'' gap opening. as you insert it into the overflow. you'll feel the bucket, just push a little farther and it will hook under the cross for the linkage. with a vice grip you should be able to pull up and force out the bucket. especially if you let it soak with the concoction of products.
                if the welding rod/ hanger bends, try again or get a thicker hanger/ welding rod. never had 1 that didn't come loose.
                what's for dinner end of the week
                  Re: Bath tub drain
                  Baked walleye! I live on a lake, you know. (Sorry Badger Dave)
                    Re: Bath tub drain
                    i thought you lived on a farm
                    moo moo or oink oink is more me
                    rick..
                      Re: Bath tub drain
                      try a #4 solid bare ground wire. i have sucked them dry with a wet vac, then poured what ever penetrating oil i had around in. have also used phosphoric acid. breid..............
                        Re: Bath tub drain
                        Update: Poured a can of Coke in the overflow yesterday. Tried the lever and still no go, so I got the coat hanger again and thought I would give it one more try. It popped out with a minimum tug!! Polished it up, put a light coat of lubricant on it and put it back. Everything works fine! Thanks again for all the assistance.
