Best Piping
  • Best Piping
    What is the best piping to use in North Carolina (+100, -0) for an outdoor shower that is exposed to sunlight and all the element?
    Re: Best Piping
    copper, it will last forever depending upon the pH in your water
      Re: Best Piping
      I forgot to mention that this is duck hunting cabin on the Albemarle sound. It sits out one the water on stilts so it has no electricity and is exposed to all the elements there is also no ground or wall insulation. The water is well fed through a centrifugal vain pump into a 55 gal tank on the roof. Water is then fed via gravity. Is copper still the best choice?
        Re: Best Piping
        With the conditions you have added I would recommend galvanize steel. None of the plastics will work and the steel is the most rugged.
          Re: Best Piping
          i agree with Utah...
            Re: Best Piping
            Sch. 80 Stainless.
              Re: Best Piping
              brass screw pipe if you can find it and afford it
                Re: Best Piping
                (+100, -0) °F I presume
                Is the exposed piping and equipment (55 gal tank) heat traced or designed to be gravity drained easily during periods on non-use?
                I did a similar setup for my brother, a year-round surfer in NJ where temps can go as low as zero in the winter. Put a 30 gal stone-lined tank painted black on the South facing roof and 'L' copper run to the shower which was setup under an outside stair way. Everything was piped and pitched so he could close one valve inside and open a drain outside and drain it all dry when not needed. The setup worked well for over a dozen years till he moved.
                  Re: Best Piping
                  (If you can afford it) Propress stainless. Pitch all the pipe and avoid traps so you can easily drain the system.
                  One other thought... I haven't used it, but there's a Viega PEX that has an aluminum (or such) covering which is marketed as retaining it's own bends. That covering might be resistant to salt and sunlight. If so, the Viega fittings are bronze which will also work. I'm guessing this would be cheaper than stainless propress. (I've never purchased either).
                    Re: Best Piping
                    The OP stated there is no electricity so I am guessing the shower will not be in use during freezing temperatures. It is gravity feed so it will need a drain down for the supply pipe and riser.
                      Re: Best Piping
                      Thanks for the Help!!!!
                        Re: Best Piping
                        no electric
                        so what turns the pump?
                          Re: Best Piping
                          Originally posted by G3sprinklers View Post
                          no electric
                          Maybe it's a very "green" hunting cabin.
