Kallista shower head thread
  • Kallista shower head thread
    I've recently moved into a house which has a lot of Kallista fixtures. The shower has what appears to be a Kallista for Town shower head which is plumbed from the wall up to the ceiling with a ~ 1 inch brushed platinum pipe which is equipped with a thread I can't quite figure out. This is the point at which you would screw on a shower head with standard 1/2 NPT thread.
    I got several new shower heads with the 1/2 NPT and they just barely start on the Kallista pipe. I tried cleaning it up with a 1/2 NPT die to no avail. I thought for a while that maybe they used a 1/2 straight pipe thread, but that doesn't seem right either.
    The thread measures 0.830 inch OD and seems to be 14 TPI. This is real close to the spec for 1/2 NPT but it just won't mate to it.
    Thoughts?
    thx
    Andrew
    Did Kalista use some weird thread to force you to buy their shower heads.
    Re: Kallista shower head thread
    3/4" npt.
    J.c.
      Kallista = Kohler
      I wouldn't put it past a Kohler engineer to decide to change the thread pattern on a product that has worked fine for a hundred years.
      They probably want you to buy the $400 showerhead to match so you can't put the $12 one that Aunt Marge gave you last Christmas
        What would one change a Kallista brushed platinum shower head too that's an improvement?
        This sounds strange to me. And a pretty expensive showerarm is now f'ed up.
        3/4"-14 NPT.
          duh, 3/4 NPT not 1/2 NPT.
          The Kallista head was gone and a cheapo was installed.
          thx
          - Andrew
            thx
            - Andrew
            Good luck. Hope all goes well.
