Shower drain
  • Shower drain
    Hi all,
    I have a 2" ABS shower drain with the rubber gasket and the fiber one. My ABS drain has a solid nut ie. when the drain is cemented to the Ptrap assembly it is solid and can't turn. What I am wondering is if those 2 gaskets go on below and I put plumbers putty in the top can I tighten the top of the drain from above??
    Re: Shower drain
    Originally posted by theclibinggod View Post
    Hi all,
    Slab? Subfloor got you tied up?
      Re: Shower drain
      Subfloor yup.
      I have this type of drain:
      http://www.bmicanada.com/products/bm...wer_drains.pdf
        Re: Shower drain
        Possible? Yes. Gonna' be hard to get much pressure on it. Don't use putty. Use clear silicone.
        Good luck.
          Re: Shower drain
          Good luck.
          as jc just said I have fixed tons of these in condos were previous plumber used puddy I would rec. also to use clear silicone 100% pure not siliconized but pure silicone
          SMELLS LIKE $$$$$$ TO ME
