ABS on a building
  • ABS on a building
    I need to make an addition in a 2 story building, the existing drain pipe is cast iron, can I run the new line on ABS pipe?
    Re: ABS on a building
    if the entire building is already n.h. i would continue with n.h.
    chances are that abs is probably legal in a 2 story building. but you need to check with your building and safety department.
      Yup, check local codes before you do anything!
      Ideal Plumbing
        How about filing a permit. Then any questions could be answered by plumbing dept. spend some money and hire a plumbing contractor
