setting closet flange over a lead bend
    Re: setting closet flange over a lead bend
    Finer, sounds like peening the lead over is the way to go in your application.
    Cast iron and lead installs can last for century if done well. I have little doubt that plastic will need replacement well before that.
      Just make sure the brass flange is anchored down to the floor good or you will have problems for sure
        Originally posted by FINER9998 View Post
        geno gardner.. please see post 6 above. no form of plastic is permitted in my municipality for either potable water or DWV.
        where do you live
        and does any one know where else lead can still be used
          I've been cutting lead flashing with a utility knife or tin snips for about 48 Years. Most of our roof flashings back east were lead. I still buy and use it out west.
            Originally posted by HVAC HAWK View Post
            where do you live
            i live in a small city in westchester county in NYS. our plumbing inspector is old school. when i politely inquired about his resitance to plastic, he stated that, in a fire, it would give off noxious fumes, to the potential detriment of the inhabitants of the bulding and any firefighters.
            my attitude is, since the PI has to approve the rough in and the install, i just do what he wants done. helps eliminate of load of grief.
              i did plumbing on LI 21 years ago and we had some towns that had a no pvc for plumbing
                hello, im new here.
                I have been reading these forums for a few weeks, and weanted to add from my experience.
                my old master and I at times would for go the closet collar in basements, he would intall lead anchors in the concrete, put some threaded rod in wax ring and set the toilet.
                I wonder if this would be a good situation to do the same here?
                regards,
                Lance
                • #23
                  thanks for the info. it seems to have turned out ok. here are some pics:
