setting closet flange over a lead bend
  • setting closet flange over a lead bend
    what's the consensus on the best way to do this? my powder room remodel was roughed in some time ago. there is a lead bend extending 14" above the finished floor. it is attached to a CI waste line with a SS banded coupling. the finished floor is ceramic tile with space left by the tile setter to attach the closet flange to the subfloor. a plumber suggested removing all but 1.25" of the lead bend that extends above the floor. place the closet flange over the lead bend and secure same to the subfloor. using a smooth faced hammer, gently, being careful not to tear the lead, tap the lead onto the closet flange, effectively "flaring" the lead onto the closet flange. there is no need to join the lead and the closet flange using heat, as in brazing or sweating, or whatwever the correct technique is called. have i been advised correctly? thanks.
    Re: setting closet flange over a lead bend
    Why not just replace it from the ss band on.Then you will know its all good.If you have to take out a little drywall in the ceiling below for access so be it .I would rather patch a bit of drywall for a job done right.
      Bad Idea! I never like the "lets smash it in with a hammer" method. I don't ever like jimmy rig solutions. I would listen to pipes15217!
        Peening the lead over or joining the lead to the flange with solder is not "jimmy rigging". It's a lost art and has been the way of doing things long before PVC and fernco's ever came out. To this day I still peen lead over a flange, and never have a leak in a preexisting condition.
        But, if the bathroom was mine...I would replace and get the lead out of there.
          I agree, replace it. It's not like there is THAT much to replace anyway.
          ....or maybe I didn't read that correctly and have no idea how much there is to be replaced, but either way, I'd get rid of the lead stuff and redo it.
          Ideal Plumbing
            pipes15217......unfortunately, this is a basement powder room. the banded coupling is underneath a platform on which the toilet sits as the soil pipe sits atop the basement floor on it's way out of the building. and replacing the lead brings up the issue of what to replace it with. no form of plastic is permitted in out municipality.
            Flux....what length of lead did you leave above the brass closet flange to facilitate a secure, leakproof peened connection to the closet flange? 1" 1.5", 2", etc.? also, what tool and technique did you employ to remove the excess lead above the cut which would leave behind the lead to be peened? would a hacksaw do the trick? thanks.
              It's very rare that I ever run into a situation in where I have an excess of lead to deal with. After I peen it over, if I feel as though I have some that needs to be trimmed, I'll heat it up and let it melt or lightly chisel it off.
              I peen lead over with a regular hammer, and do little bits at a time all the way around the flange. The key is NOT to go gangbusters like you're driving a 16 penny nail home.
              When I'm done, it's the ONLY time I will use a "horned" wax ring to set the toilet for added protection against leaks.
              Others might deal with it differently, but this is the way I was taught.
                Flux is dead on with his practices. Same as mine
                  Flux i did this a lot in NY 21yrs ago and loved doing it ,i said that you were a plumber back then . i use to solder it it with 50/50 solder with a little heat .
                  i think i still have some 50/50 solder around
                    i ask about the amount of lead needed for effective peening and a cutting technique as the plumber who did the rough in left 12" of lead sticking up out of the flloor. i'm no professional plumber, but i suspect that's just a little to much to peen over. so, while i appreciate the very quiuck responses, i'm afraid i'm back to the quantity and technique question posted previously. thanks.
                      I think I even have some 50/50 laying around still.
                        I'm tired tonight, and absolutely missed that you said you had excess sticking through. If I was in that situation, I would lay the flange next to the lead, and cut it off "about an inch" above the top of the flange. You should have more than enough to complete the task.
                        I never had to cut lead with that much sticking through, so I'm sure a sawzall with a metal blade would work. Someone else will have to chime in on that one.
                          I'm with Flux on this one. I would rip out the lead and go back to the stack installing PVC or new cast.
                          However, if you want to be old school, I would put down a brass flange that I pretinned, peen the lead over the flange and then solder the lead to the flange. It's been at least a decade since I did it, but I prefer a waterproof joint. Make sure you wash off all the flux after you do this.
                          If the lead bend is essentially new and unused I would consider doing the latter if you're good at soldering and enjoy a project.
                            you said this room was roughed is some time ago ,how long ago .
                            i did not they still used lead any more ,do they ?
                              geno gardner.. please see post 6 above. no form of plastic is permitted in my municipality for either potable water or DWV. the lead bend is joined by a SS banded coupling to CI and is under a tiled platform so it is absolutely inaccessible without tearing up the tile, subfloor, etc. since the best the plumbing inspector will allow is to replace the lead with CI, there's little to gain,as far as i can see, to changing what the plumber roughed in. i believe he went with the lead as we weren't absolutley sure what the finished flloor height would be. apparently, with the lead, i can easily cut it to the height needed.
                              HVAC HAWK...the rough in is probably 4-5 years old and the house is around 90 years old. the project has been interrupted many times. as the rough in plumber is a family friend, i suspect, as noted above, that he chose the lead because we weren't sure what the finished floor height would be.
                              i'm actually pretty enthusiastic about the lead. it seems to be a good material for this particular application and, if connected to the brass closet flange correctly, should see decades of problem free use.
