PEX pipe help!
  • PEX pipe help!
    I recently built a new home and all of my water lines are ran with PEX pipe. I noticed when I turn the Hot water on, the PEX lines stretch and bend a lot more than I think they should. Some of the 90 degree corners look like they might snap under the forced pressure.
    Is this normal? I only noticed this when I painted my basement ceiling with primer and black paint. I left the floor joist's open. The main part of my basement is a gym and I wanted a commercial look. Rather than dry-walling the ceiling, I rented a sprayer and sprayed everything, duct work, electrical, joists, and water lines etc...
    Where the PEX line run's through the joist's I could not hit it with a sprayer. When the water lines heat up, I can see approx. 1 1/2" of un-sprayed PEX line. When the pipes cool I can no longer see the unpainted PEX line.
    Any help would be greatly appreciated.
    Re: PEX pipe help!
    it's normal for pex, you're supposed to limit your use of 90's and bow the pipe.
    You're also not supposed to get paint on pex.
      Re: PEX pipe help!
      What does paint do to PEX?
        Re: PEX pipe help!
        It reducers expansion and contraction especially on hot water lines.
        Tony
          Re: PEX pipe help!
          When I contacted Uponor about spray foam coming in contact with their product, their reply was essentially to not allow any product to come into contact with their fittings, wrap them with several layers of plastic and zip tie the ends closed before spraying. And that the coating manufacturer would need to test their product compatibility with the piping and provide their own documentation to uponor to maintain the warranty.
            Re: PEX pipe help!
            Pex should not be pointed.
            Which brand of pex did you use?
              Re: PEX pipe help!
              Originally posted by ruplumber View Post
              pex should not be pointed.
              or painted !
                Re: PEX pipe help!
                The expansion and contraction is normal in PEX. Painting the PEX is not so you may want to start a budget to replace all of the painted PEX before it fails.
                  Re: PEX pipe help!
                  eventually you will have showers for your gym. smooth. breid...............
                    Re: PEX pipe help!
                    Also, I would not have painted the electrical wiring.
