Symmons Metering Faucets
  • Symmons Metering Faucets
    Hello I am having a problem with Symmons Scot metering faucets. The place has 10 of them and all of them need various parts replaced. The problem I am having is I use the 3/32 hex to loosen the screw in the handle. First I can't seem to get any of the hex screws out and if I seem to loosen them I cannot get the handle off. I have a faucet handle puller but there is no way to use it on this type of faucet. Any ideas?
    Re: Symmons Metering Faucets
    Drill the screws out and re-tap with a larger screw....or break the handles off the stems,replace the stems and handles. Plumbers grease is good to use on all metal to metal and threaded connections on faucet trim.
      Bummer I see the set screw is in the back of the handle. I would break them off and replace the cartridge and the handle or break them off and then drill them out,tap and fit with a new set screw with grease and grease on the cartridge stem and the handle before its re-installed
