2 Questions
  • 2 Questions
    Are all Fill Vales created equal for a toilet. Mine is sticking and is starting to cause water hammer issues right as the tank fills....Is their a particular brand of Fill valve that I should be looking to get?
    I'm sure most of you have seen the Mertordome collapsing becuase of the snow here in MN.. Well my house had 3 ft drifts on the roof....While I was clearing the roof I remember the vent pipes became full with snow.. For the last few days after we flush the toilet I hear gurgling sound in the drains. Yes I'm fairly certain its the blocked pipe
    My question is will the warm air coming from the pipe eventually melt this blockage or do I need to climb up there and unclog it? How common is this in high snow areas?
    Re: 2 Questions
    don't know about snow as i'm still in a t-shirt
    as far as ballcocks, i would stick with a fluidmaster 400 or pro-45.
    these are used in 80% of all new toilets.
    plus the parts are a dime a dozen and have a very long service life. also change the toilet flapper and dye test the tank water.
      Re: 2 Questions
      Originally posted by fall50 View Post
      ... My question is will the warm air coming from the pipe eventually melt this blockage or do I need to climb up there and unclog it? How common is this in high snow areas?
      Even though I am routinely on roofs in all kinds of snow, deep is fun!, I would let the warm air from draining water melt the blockages.
      You likely have other vents not blocked.
      Also "venting" through your sewer line.
        Re: 2 Questions
        as what Robert Gift said the warm air from the water will evenyualy unclog the vents depends on how much usage and if you use hot or cold water remember heat rises
        SMELLS LIKE $$$$$$ TO ME
          Re: 2 Questions
          well no heat does not rise. hot air rises. heat radiates, hot to cold, always. breid............
            Re: 2 Questions
            agree fluidmaster.
            agree don't worry about blocked vents; vents are highly overrated. Their only purpose is to prevent traps from being sucked dry. your gurgling may be that, may be symptom of another problem. I have yet to see any drainage problem result from a vent issue.
              Re: 2 Questions
              And when it comes to hot air ... if you're going to getechnical, heat can also be conducted.
              (Wonder if I can get my toilet bowl gas evacuator to be GREEN-powered by warm air drafting up a vent?)
                Re: 2 Questions
                but, in practice, most heat transfer we deal with occurs through convection.
                  Re: 2 Questions
                  heat, hot air, whats the differents both start with H
