Insulation?
  • Insulation?
    If an electric water heater is inside a living space where the highest temperature for the area will only be 50 degrees......does it need any insulation on it at all?
    Thanks.
    Re: Insulation?
    Not if you set the stat at 50 degrees.
      Re: Insulation?
      Love this answer! LOL
        Re: Insulation?
        I would insulate the hot pipes so to help prevent heat loss.
          Re: Insulation?
          Why would it need any insulation? Why not just the raw steel tank?
          Thanks.
            Re: Insulation?
            Cause the goberment done says it needs insulation cause we is all to stoopid to figger things out for ouselfs. Gots to meat enegy codes
              Re: Insulation?
              don't the heaters already come with 1''-2'' of foam insulation under the outer shell?
              we have gas heaters that are required for new construction that are r18 insulated.
              electric heaters are similar, but i might only do 1 a year out here.
                Re: Insulation?
                I've found that if you wrap an electric heater in a cool climate that it condensates inside the jacket and corrodes the terminals
                  Re: Insulation?
                  Thanks.
                  So the water heater is helping heat the house. Yeah its not made to do that with.
                    Re: Insulation?
                    I was told not to add a blanket to the new water heaters with foam insulation under the TIN
                      Re: Insulation?
                      most likely due to the fvir air intake you would be covering
                        Re: Insulation?
                        Or the manufacturer's CYA warning stickers!
                          Re: Insulation?
                          "the highest temperature for the area will only be 50 degrees"......
                          What would be the lowest temp that same area will go to? What is the stat temp set at?
                            Re: Insulation?
                            This is nothing more than a hypothetical question as I sometimes am just thinking. So the lowest temperature is not known.
                            Just wondering if some places with cold environments (aka, low average temperatures) could somehow take advantage of the standby radiant heat loss from a tank.
                            Could maybe work. But there would probably be problems with temperature control.
                            Just thinking. Probably dumbly/dangerously.
                              Re: Insulation?
                              I was reading a water heater insulation blankets instructions and it says to not block any air flow to the burner on gas models and on electric models to cut the blanket away from the electrical componets because it can overheat and deteriorate wiring. Thats a summary
