Ridgid 4087 sump pump
  • Ridgid 4087 sump pump
    The pump does not turn itself off...just keeps running. Not sure if it is a part I need to replace or how to fix the problem. All the snow is going to melt soon...help!!!
    Re: Ridgid 4087 sump pump
    I am not getting any info on the web on that model Ridgid 4087 sump pump did you write down the correct model # even if so more then likely your problem is the switch not the pump but I still would rec. replaceing the pump if its more then 2 years old as a switch is 1/2 the price of the pump and same labor still need to take the pump out to replace the switch
    SMELLS LIKE $$$$$$ TO ME
