Leaks in fittings
  • #31
    Re: Leaks in fittings
    Originally posted by scraple View Post
    I only just got done with it about 2AM this morning!!!! I haven't tucked them in the cover yet.
    Sorry. I got a little over excited.
    I got shocked last week.
    • #32
      Please show us the T+P ,I'm worried now!
      • #33
        I know, I know... I will tuck them in immediately. I'm not going to give you all anymore heart attacks. Thanks again!!!!
        • #34
          it looks like the hot is CPVC so your good
          if you have to fix that side the glue is different for cpvc and pvc
          do not over tighten the pvc to much it will crack
          • #35
            no more questions
            i'm worried about you catching up to my post count
            13 already and it's only a couple hours
            p.s. that goes for you too j.c.
            • #36
              no more questions
              i think JC is trying he has a lot of new posts every day
              • #37
                I have an overdrive speed you haven't even seen.
                • #38
                  HVAC Hawk- yes, I did use CPVC on the hot side and I made sure and used CPVC glue. I used to follow my Dad around when he was working around the house (I was the tool fetcher and hander) and he always explained what he was doing and why, so I knew about the differences in the pipe. I always use cleaner too prior to glue. I also took automotive mechanics (I got put in the wrong program- was supposed to take cosmetology) after high school, and I worked in a maintenance shop once in the parts department. I actually like mechanics, carpentry and things like that. If I'd had a plumber for a dad, I'd probably be one of you guys by now, but Dad was a draftsman fulltime, carpenter-mechanic on the weekends. Thanks for your reply!!!
                  • #39
                    THE REASONYOU DON'T USE PVC INSIDE IS BECAUSE IT GETS VERY VERY
                    BRITTLE OVER TIME THEN YOU BUMP OR JAR IT AND IT BREAKS APART !
                    SO IF YOU WANT TO THINK ABOUT WHAT IT WILL BE LIKE HAVING THAT
                    PVC COLD PIPE BLOWING WATER OUT IN THE ROOM AT FULL PRESSURE
                    TILL YOU GET HOME AND FIND THE MAIN SHUT OFF VALVE ?
                    THAT IS WHY PROFESSIONAL PLUMBERS USE CPVC ON BOTH COLD AND
                    HOT WATER LINES IN SIDE OF THE HOUSE ! !
                    JERRYMAC
                    E-MAILJERRYMAC777@GMAIL.COM
                    FIRE SPRINKLER CONTRACTOR,
                    SINCE JAN. 1989
                    • #40
                      no more questions
                      If I was you Rick I would be more worried about JC at nearly 8,000 in only two years and you at 12,615 in six years you`d better get a riggle on and not stand on your laurels
                      Tony
                      • #41
                        Tony
                        He'll always be on top of the Post Count. Trust me.
                        • #42
                          I`m starting to wonder if you ever sleep J C ????????????
                          Tony
                          • #43
                            Tony
                            No. I'm like the Santa Claus of plumbing.
                            "I see it when it's leaking, I know when it is clogged....." (Santa Claus is coming to town. )
                            • #44
                              Since we are talking about post counts.....does anyone ever go back and read the posts the posts you make and see how many of them are on subject......or even about plumbing?
                              • #45
                                WAY too many of mine are just uninteresting B.S.
                                Like this one.
