Hot Water Circulator
  • Hot Water Circulator
    I presently heat my home with a coal stoker boiler that has a DHW coil in it. I would like to use a small circulator between the coil and my hot water tank along with an aquastat to furnish my hot water needs.
    The question I have is which pump would be a better choice. The Taco 006 Bronze 1/40hp or the Grundfus Hot water circulator with a built-in timer and aquastat?
    Thanks
    BTW I already have a tempering valve in place for safety.
    Re: Hot Water Circulator
    i prefer the grundfos over the taco. also the pump is a bonus along with the stainless steel construction.
    don't get me wrong. i also like taco when it comes to lunch
      While bronze sounds good, the weakest link is what counts.
      I run into & hear of quicker failures with Taco cartridges.
        taco is my choice and you can get them with a temp control on them
        i put in a small pump a week or so ago that had a temp control on it i forgot the name ,i will get it tomorrow
