De-Liming Question
  • De-Liming Question
    I have a coal fired boiler with a DHW coil. I am getting ready to tie it into my DHW tank and have a question. I was thinking of making provisions for de-liming the coil if/when it may be needed. Is there a really small pump or set-up someone could reccommed?
    Thanks!
    Re: De-Liming Question
    Thanks!
    Not many companies make acid pumps, and we just replaced ours last year, and the brand name is slipping me at the moment.
      I've used one of these. Pump didn't last long though. Maybe 5 or 6 uses.
      http://www.pumpbiz.com/shopping_prod....asp?pcid=5735
        The Pump we use is by Nu-Calgon.
        http://www.nucalgon.com/products/pro...d_descaler.htm
          flux
          whats the life span of 31tx? breid.................
            Re: flux
            We probably clean 2-3 coils a year, and our last pump was easily 10 years old. I'm sure if you were to use it more, it could shorten the life span I suppose.
