No hot water...have you run into this before?
  • No hot water...have you run into this before?
    Check out my YouTube animation and see if you can resolve it? Here is the link....http://www.youtube.com/watch?v=Zl8T5If8s2I
    Re: No hot water...have you run into this before?
    Bad flame sensor( rollout switch ) just grabbing for things
      Vent hood was creating a vacuum drawing outside air DOWN the water heater flue.
      What do I win?
        You win a free trip to Hawaii.....just kiddn....ya...when the temperature dips below -20 degrees Celcius here it becomes heavier and tends to cause problems like this one. Its usually due to poor makeup air..too small or not working. It could be remedied with a blower vent fan installed on the vent if the problem persists..
        cheers...Fred
          cheers...Fred
          you say win for what I say it sounds like a bad return air causing a down draft on the flue the cure fix the return air easy way to check open a door then the flue will work properly
          SMELLS LIKE $$$$$$ TO ME
