water heater supply lines - stainless or copper?
    Re: water heater supply lines - stainless or copper?
    Is there any statistical data to support that the Flexes help in earthquake areas being that the heaters are also strapped with approved methods?
    Thanks.
    I think the purpose of the strapping is to prevent a heater from tipping over, so I'm pretty sure SOME movement is still expected and if you run any hard pipe/tube directly to the heater, you do run a risk of a joint failing if not worse.
    Ideal Plumbing
      aram, you just missed the special last week at hirsch. i think i now have 200+ ss water heater flexes. when the next big one comes, he who has the flexes will be the guy that gets the work
      let me know what you need and i'll keep you in the loop.
        Thanks.
        Many years ago the strapping I saw on places I lived in CA wasn't more than a best-efforts attempt using plumber's tape. But in the last decade (approx) the inspectors have been enforcing the code which requires some heavy-duty bracing per spec.
        I saw a thread on this topic in another forum but I can't find it now. I recall someone stating that the bracing wasn't really needed until the hard-piping was replaced by flex, since the flex allowed for movement of the WH. Another person commented that piping should only be used for transport of fluids/gas and not structural support. I recall it was a spirited discussion...
