anything wrong here?
  • anything wrong here?
    Here is how my washer discharge pipe connect with the sewer line. I was like this when we moved in. I remember last time a plumber told me the inspector complain the discharge line with him. Anybody can tell me what's wrong with this setting and how can I fix it?
    The only thing I can think about is the entry in the main line is a cleanout and should not be used. If that is true, can I correct it by add a tee there and free that cleanout?
    thanks,
    Re: anything wrong here?
    thanks,
    Not enough info but it looks like it might be wet vented and the trap arm may be too long. Is there anything else draining into the drain from above? I'm also wondering what else is shoved down the stand pipe?
      above is the kitchen sink. the length of the arm is about 6'.
        Does is it currently work? If it does well then there u go...would need to know what that means inspector didn't like....
        Derek
          You need to enter the drain through a sanitary fitting, add a VTR and shorten your trap arm.
            few months ago the inspector came to my house for another plumbing project. Then the plumber told me the inspector told him something there didn't follow the code.
              Well that sucks he didn't go further into detail...I hate when that happens...
              Derek
                Codes do vary. It will not pass code where I am at.
                I have to say that I don't understand posts like these. According to your posts, you've had a plumber and an inspector there but don't know why it doesn't meet your local code.
                Seems like you could find out from them in 5 minutes.
                  I cannot understand this. what's you mean about "through a sanitary fitting"?
                  add a VTR
                  Is this mean the vent through the roof? I checked before. There is a vent goes up to the attic from the kitchen sink and then finally goes through the roof.
                  Yes, I will move the washer closer to shorten the trap arm.
                    The trap arm is tied into the old clean-out fitting which is not a legal connection.
                    That is the vent from the kitchen sink but you have no vent for the laundry.
                    You are probably better off having a plumber do it as it may be above what you are use to.
                      As long as that vent goes through the roof, from what I see that would pass in my state. You're within 6 feet, and their is an "exception" in the I.P.C. code for connecting to clean-outs. Unfortunately, I forgot to bring my code book home today from the shop.
                      But your state might be different code wise.
                        Except that it is not a vent it is the waste from the kitchen.
                        Table 706.3?
                          Instead of utilizing the existing test tee for the connection , The plumber probably should have removed the piping out of the hub above the floor , installed another cleanout , stacked a 3x2 tee on top of it for your washer drain, and if longer than 6' installed a studer vent(legal here)..Tied back into the cast iron above it with a fernco and shearband...Or something similar.. The inspector probably had an issue that there is not a 3" cleanout for that stack now..just my .02
                            Table 706.3?
                            I have a hard time believing that the line we see in the pictures, doesn't vent through the roof. But it could...we just don't know. If it's not vented, that throws everything I said out the door..it's illegal.
                            I forget what table it was...700's sounds about right.
                              To me it looks like someone just installed a trap arm to the cleanout at the bottom of the kitchen waste but who knows for sure.
