p-trap question
  • p-trap question
    I noticed that all p-trap only have one side connect to horizontal line. Why we cannot install p-trap on both side horizontally? because it will slow down the flow and clog the line?
    Re: p-trap question
    That's part of it. By code, (Fla.), the trap shall be placed as close as
    possible to the fixture outlet. The vertical distance from the fixture outlet
    to the trap weir shall not exceed 24 inches. Clothes washer stand pipes
    fall under a different rule. One example of a horizontal trap inlet and outlet
    is a building trap which is prohibited under our code, except where local
    conditions necessitate such traps. (I know, I know). And when used there
    must be a cleanout and a relief vent on the inlet side of the trap. Also, traps
    need to be self-scouring. Let the obfuscation commence.
      Re: p-trap question
      Basically, you are describing a running trap, and codes don't like that
        Re: p-trap question
        [QUOTE=lovetheUSA;332011]Basically, you are describing a running trap, and codes don't like that[/QUOTE
        Bout the only running trap allowed is on condesate drains for a/c right?
        Derek
          Re: p-trap question
          [QUOTE=dcman;332021]
          Or to get out of an overhang back into a heated space
            Re: p-trap question
            And don't forget S.F. IS FAMOUS FOR CABLE CARS AND WHOLE HOUSE TRAPS !
              Re: p-trap question
              House traps can be considered as running traps as well.
                Re: p-trap question
                Forgot about that...don't have many here...
                Derek
                  Re: p-trap question
                  Originally posted by toolaholic
                  And don't forget S.F. IS FAMOUS FOR ... WHOLE HOUSE TRAPS !
                  Why did they do that?
                  Do they have a ground vent for the sewer line just after the house trap?
                    Re: p-trap question
                    Insp, said with the steep hills the velocity of the sewer , and street runoff water, could siphon the fixture traps
                      Re: p-trap question
                      Wondered about the velocity.
                      But would that not also siphon the 3-inch trap - if that it what it is?
                      Do they have a vent after the house trap?
                      Does rain water also enter the sanitary sewer?
