Anyone know where can I find a 5" OD -4 7/8" ID, 1/16" wall white plastic pipe?
  • Anyone know where can I find a 5" OD -4 7/8" ID, 1/16" wall white plastic pipe?
    Wow, I would have never thought it would be this hard to find this pipe. Anyway, Like I said, this pipe is 5" thick outside diameter, with 4 7/8" thick inside diameter with a 1/16" thick wall and it needs to be white and I need several 40" lengths.
    Any suggestions? thanks for any help at all.
    Re: Anyone know where can I find a 5" OD -4 7/8" ID, 1/16" wall white plastic pipe?
    problem is that is not standard plumbing pipe.
    you will have better luck checking with a plastic/ pvc supplier.
    does it have to be those exact dimensions?
    what application? too big for a potato cannon
      Hey Rick, thanks for the quick reply.
      I need to match some existing older pipe and fittings with those dimensions, so yeah, I was hoping that I could find it that size, otherwise I will have to replace a whole bunch of it. BTW it isn't under any fluid pressure. It's part of this drain overflow system in an old building. Thanks again.
        They grow some big 'taters in L.A. (Lower Alabama)
          Is there any writing on the pipe? Like ASTM with a number after it, or SDR and some number or SCH with a number.
            No, there is no writing at all on the pipe that I can find. It's fairly old.
              Probably gonna' have to measure some Fernco or similar type couplings and make a transition to a standard size pipe.
                Thanks for the advice guys.
                I thought about attempting to make the replacement pieces out of fiberglass and tinting it to match what I have, not sure yet but I've done a few small fiberglass jobs, so I know what's involved. I wouldn't worry about matching the other pipe except the fact that I see these pipes every day, all day long, and I don't want to look at it if it doesn't look right.
                Oh well, anyway, thanks for the reply's.
                  check out NDS pipe NDS is National Diversified Sales
