which way is better?
  • which way is better?
    from ground 3" stack, I want to convert to 2". should I convert immediately and than add cleanout and another tee, or should I add a 3" cleanout and 3" tee then convert to 2"? which way is better?
    Re: which way is better?
    Keep it with a full size cleanout tee. That way if you ever need to auger the line a full-size cutter can be used. Also don't stack your fittings so close unless absolutely necessary. Leave yourself a little room in case you want to add something later.
