Just purchased a SSP-1000 (advice on install)
  • Just purchased a SSP-1000 (advice on install)
    The previous owners had an archaic pedestal style sump pump that recently failed on me this morning. I purchased this unit as a replacement and right now I used a brute-force method to evacuate most of the water from the basin as my piping was 1.5 inch and the pump to the outside world was just 1.25 inch (so yeah, I had some water spraying out of the top).
    this makes me want to do a couple things...
    1) get a check valve and thread it into the pump and attach the hose into that to prevent water from escaping down into the basin again
    2) Get a backup sump pump (which one should I get???)
    this begs me to ask the following:
    Should I use PVC piping instead of a black flexible hose? I am contemplating outsourcing the work to a contractor as I just don't have the time, but I also don't want to spend extra if I know this all could be done in an afternoon.
    I have time....water is not flowing into the basin as we are still in the winter season.
    Paul
    Re: Just purchased a SSP-1000 (advice on install)
    Paul
    well I would say yes to the pvc pipeing you should never have flex hose in the house conected to the sump pump and there should be a check valve apx 3' up off the pump and about 2" above the male adapter there should be a 3/16" hole drilled in the pipe to help prevent hydro lock
    SMELLS LIKE $$$$$$ TO ME
