sump pit
  • sump pit
    I have not been able to search and find an answer to my sump pit problem.
    50 year old house deep enough sump hole. My problem is that there appears to be water coming in under the footing at the bottom of the sump pit. The wall appears to be eroding a bit. The tile hole is 10 inches above the spot of the erosion. A fair bit of water is coming through the erosion spot. Should I be patching the erosion or leaving well enough alone?
    Rick
    Re: sump pit
    Derek
