Dishwasher question
  • Dishwasher question
    We have an older Maytag dishwasher.
    Usually it runs just fine, however, there are times
    we get a "blocked washer arm" indication and the unit
    stops until we open and close the door.
    This can occur if we have the dishwasher loaded to the maximum
    or half empty.
    I have been unable to determine any specific pattern or cause for
    the alarm.
    I do run the dishwasher empty every so often to make sure
    all is clean and clear.
    I also have inspected the top and bottom wash arms to ensure the spray holes are clean and open. Yes, I remove them, wash them out and look where they are attached for debris....
    Now, I realize the manufacturers are messing with the dish soap
    ingredients again and have removed what ever phosphates
    were still in the formula. We tried those liquid gel capsules and different brands of dish washer detergent, there is no difference.
    The dishwasher does go through the various cycles correctly
    [other than the blocked wash arm alarm] and
    the dishes come out clean. etc. We do have a water softener.
    I'm just trying to determine why the blocked washer message
    keeps happening. Of course the Maytag documentation is worthless.
    Any comments are appreciated.
    Cactus Man
    Re: Dishwasher question
    When you say older what does that mean? How old....model number ??
    Derek
      i would think the problem is in the sensor that trigers the alarm. is it a pressure switch? or an electrical overload?
      chances are if you google that problem, there will be dozens of threads on what to do.
        Dishwasher specific information:
        MAYTAG
        Model DWU9962AAB
        Serial 10148177QH
        Vintage/installed 1997
        It seems many folks [Google] have similar challenges with
        "blocked wash arm" messages
        The Maytag website does not have any useful information
        regarding this anomaly.
        One comment was to ensure the drain hose is at the correct height...
        It is!
        I did read one more comment about cleaning the "filter pump
        screen" item 6
        I do not have any drainage problems
        Cactus Man
          Is it possible that if a spray stream deflected off an item and back against the spray arm, the system may detecthat resistance and signal a problem?
          Aren't all arms powered by water spray and not mechanically turned?
          Thank you.
            This older style had a sensor that goes bad...about a 200-250 part...probably not worth fixing...plus I think its a hard part to find...(This information comes from my uncle who is a appliance repairman...)I personally just bought a really nice Maytag for about 400.00 so 14 years is pretty darn good...
            Derek
              MAYTAG
              Model DWU9962AAB
              Serial 10148177QH
              It is!
              screen" item 6
              Cactus Man
              An excellent help forum on appliances is www.appliancejunk.com
                dcman: I bought two Maytag dishwashers' a few years back. They were middle of the road Maytags. Neither cleaned dishes very well, and neither lasted longer than six years. I installed Kitchenaid dishwashers. They have worked fine ever since (a decade at least) and they clean much better.
                  Middle of the road...does that mean like lowes or home depot level? Mine is a grade above those, with a softener, and so far I have been very happy...Not taking anything away from Kitchen-aid...they used to be the shiznit, but I think its like Maytag, you gotta spend above consumer grade stuff to get a good product...
                  Derek
                    Just for those with too much time on their hands....
                    "How come only expensive parts break?"
                    Cactus Man
                      I bought a G.E profile dishwasher 11 years ago and its great. Washes until the dishes are clean....no matter how long or how short the cycle is,the machine decides. Another one of those fancy sensors I guess
                        Cactus Man
                        How else can they pay those CEO's million dollar bonuses?
                          ....Government Conspiracy....
                          Derek
