Are "bog box" water heatersame as name brands?
    Re: Are "bog box" water heatersame as name brands?
    Yep, it is a cool new one, just amazed at what they all cost, all the brands !
      Originally posted by geno gardner View Post
      Personally, I would get a water heater with a six year warranty, and install a 2nd anode in the hot water side. This will sacrifice itself and help the tank last longer.
      Forgive my ignorance as I haven't been in the plumbing scene for the past 8 months but where is a hot water side on a water heater?
        Silly question the hot side is located opposite the cold side of course.
        Normally the hot is on the left side when the gas control valve is in the front. The top of the heater will normally have raised text labeling the hot and cold openings. The can't fail way to determine what's hot and cold is to locate which opening has the dip tube. The opening with the dip tube is the cold.
          GE is made by Rheem. One difference...most HD models except maybe the 12 year...have the plastic drain valve. You have to be careful about in store damaged-in-handling.
          The lowes Whirlpool are labeled as made by US Craftmaster, an AO Smith brand. The gas models have been the subject of class action lawuits and several THOUSAND internet forum and blog posts@!
            Is there now water heaters with 2 places for an anode?
              craig, remember that these guys don't need the lo nox models like us. so figure at least 100 less than us
              Do any residential water heaters or furnaces come with lo-NOx burners?
              Would such burners lessen natural draft up the water heater center tube which cools the water 24/7?
              Cleaning a chimney after dark in December, I warmed my hands over a furnace vent.
              Neither the furnace nor water heater were burning.
              Was amazed at how much heat was lost from the water heater. Additionally, that draft was pulling frigid air into the basement which replaced the air lost up the flue, chilling the basement.
                typically the tank has a 3/4'' port for the factory rod at the top. then they also sell a hot water nipple/ anode rod.
                • #23
                  http://www.waterheaterrescue.com/pag...ium-Anode.html took me a little lookin but this shows a pic.
                  SMELLS LIKE $$$$$$ TO ME
                  • #24
                    In the northwest suburbs around here,tanks will fail under warranty without the secondary anode.Here is an 8 year old secondary anode next to a new one, from Maple Grove
                    • #25
                      Jay, nice pic!! That's why I put the anode in the hot side on all my water heater installs, even in the cities.
                      • #26
                        to be honest I never herd of a hot side anode rod till this thread just somethig that must not be used much here
                        • #27
                          Which pic?
                          The avatars ^ are getting better!
                          • #28
                            I learned something too. I didn't realize you can "herd" anodes.
                            • #29
                              HA HA ..herd anodes..you guys kill me!!!!
                              Derek
                              • #30
                                I've used a second anode rod on the Hot side quite a few times.
