Fittings
  • #76
    Re: Fittings
    Here is some more info.
    http://www.ppfahome.org/pex/faqpex.html
    This was copied from the link above.
    Can PEX be used for underground cold-water service applications?
    Yes. Although the high temperature resistance of PEX makes it particularly suitable for hot and cold interior plumbing applications, it also makes an excellent underground water service piping. The new AWWA C904 standard also applies to PEX used in this application. PEX can be installed using the same fittings recommended for copper tube sized SDR-9 polyethylene tubing.
    • #77
      Re: Fittings
      You lost the 100.00! It was done by a plumber. I am probably doing this *** backwards. I should have asked BEFORE the installation and not afterwards. The only thing I am accomplishing now is second guessing the installation/plumber. By the way, I sent you a PM.
      Originally posted by TheMaster View Post
      I have 100 bucks that says he did it himself. Thats why all the questions.
      • #78
        Re: Fittings
        really? , why's that?
