connect to cast iron hub with donut
  • connect to cast iron hub with donut
    when you connect a new cast iron pipe into a hub with donut do you use other method to help seal the joint or the donut itself is good enough?
    Re: connect to cast iron hub with donut
    The donut is the seal.
    Nothing else needed to seal.
    Test according to local code when finished.
    But, I would have gone with the lead wool option.
      We can only pour lead joints above ground here in IL. Push gaskets are allowed underground only. I have no idea what Boston/MASS require though
        Is PVC or No hub cast iron legal above ground?
