Drainout Plug
  • Drainout Plug
    I have what appears to be a tough question for my local home improvement stores
    I have a 2.5" drainout and am looking for an expandable plug to seal it but the only sizes in every store and in every online store I have searches is either 2" or 3" and neither of which will seal a 2.5" (Even though one salesman assured me the 2" would, but that was not correct)
    Any suggestions?
    Re: Drainout Plug
    Any suggestions?
    I'm not sure what a "Drainout Plug" is but if it is a cleanout plug you need to replace it with a cleanout plug. I doubt anyone makes a 2.5" expandable test plug. That's not to say you could not adapt something to work but it wouldn't be right.
      Re: Drainout Plug
      Yes, you are correct, I guess it's called a cleanout plug
      And why would they not make that size (2.5") when some are that size?
        Re: Drainout Plug
        a 2.5'' plug is typical for a 3'' cleanout tee/ iron body cleanout.
        if the threads are still good, then install a 2.5'' brass or plastic plug. if the threads are shot, you might be able to force a 3'' expansion plug into the 2.5'' threaded opening as it's size is closer to 3'' than 2.5''.
        2.5'' plugs are more of a supply house item than a diy store.
          Re: Drainout Plug
          Wouldnt a DIY house have the same stuff as a supply house?
          And what kind of store is a supply house? (Any names or websites for a couple?)
            Re: Drainout Plug
            I'm not aware of anyone who makes a 2.5" plug to use in place of a cleanout plug. They do make 2.5" pipe plugs but that would cost a lot more than a cleanout plug and probably not work as intended.
            The difference between a supply house and a DIY store is like the difference between a 7-11 and a Costco.
              Re: Drainout Plug
              Ditto to what Rick said.
              I keep 1 brass 2.5" plug and 1 lead fit all plug on my truck for such situations.
                Re: Drainout Plug
                The brass plug will not go back on the outlet because f the concrete I had to chip away to clear the outlet, so the only option would be for an expansion plug
                I refuse to believe no one makes an expansion plug to fit a 2.5 outlet, that makes no sense
                  Re: Drainout Plug
                  http://www.usplastic.com/catalog/item.aspx?sku=25102
                  something like this?
                  Derek
                    Re: Drainout Plug
                    Yup, it's not that they don't make them, it's just that you will have an incredibly difficult time finding one (at a reasonable price too once you do find it)
                    Like we said, 2.5" is not a very common size in plumbing.
                      Re: Drainout Plug
                      I pull out a fair amount of homemade ceder plugs around here in Cast Iron.
                      Old timers would just make a wedged shape piece of ceder and hammer it in.
                      Sounds crazy but in all honesty I've never really seen one that didn't do just as good if not better then an expanding plug, brass cap, or a lead fit all.
                      I use to think it was a funny backwoods hack way of plugging a clean out but now I'm beginning to wonder.
                      They last a heck of a lot longer then an expanding plug.
                      They can Handel head pressure just as well as a brass cap but actually come out with little effort.
