bathtub is clogged, sink makes burping sound..
  • bathtub is clogged, sink makes burping sound..
    but the toilet is ok. this bathroom is on the third floor. i've tried with a plunger, a 4m snake.. please, help me if you can. thanks in advance!
    http://www.youtube.com/watch?v=IYie9f5Zoi4 also please forgive my ignorance in this video. thanks
    Re: bathtub is clogged, sink makes burping sound..
    Well done video!
    Clog beyond the bathtub?
    Can you use a longer snake?
    Or snake upstream from another location?
    Or insert snake down the roof vent?
      That looks and acts like a Buried drum trap. Have fun
      Jam a rag in the sink drain and over flow pop it with an air RAM.
      Stat at around 15 psi
      Rod
      http://unclognh.com
        Well done video!
        hahaha! i shot that with a small canon camera.. thanks for taking the time to watch it.
        i'm not a plumber, so i can not confirm that, but the toilet, at the right of the sink, is ok.
        thank you for your advice. i just came back from hd, & asking lots of questions to the salesmen, with a 25' ridgid snake..
        there are only 2 sinks in the apartment (1 in the toilet and another one in the kitchen), 1 bathtub & the toilet.. the kitchen sink is ok.. you mean i must snake from the.. toilet?
        thanks for the advice! do you think my new 25' snake will do, please?
        please take a look at this picture: is this the roof vent? thanks
        http://img807.imageshack.us/img807/4990/roofvent.jpg
        thank you robert gift for your time, advices!
          thank you unclognh for your advice. please i'm new at plumbing.. i googled 'buried drum trap'.. but i would like to hear explanations from you more about it please .. if you have the time? thanks
          Have fun
          oh no! i'm having big headaches right now!
          thank you again for your advice. i understood the first part, but please what is an 'air ram'? thanks
          ok, thank you.
            Have fun
            ok, thank you.
            I have a drum trap in my bathroom and when I plunged it looked exactly like that. I am guessing all that crud is sediment from the trap.
              Put a wet rag in the overflow while you are plunging the tub drain..Slam it with some authority..You might get wet but so what
                Don't forget to get somebody to plug the drain and overflow on the lavatory....
                Derek
                  Why ruin all the fun and surprise?
                  I make a good plumBob but am not a plumber.
                  I would not go through the toilet. Its 3-inch line is probably clear.
                  If not, some of the slug of water from flushing the toilet would probably come up through the bathtub drain.
                  25 feet should be more than enough to reach a clog in a bathtub and vanity drain. But maybe there is.omething unusual and the line is long.
                  WEDNESDAY: Just saw your roof vent.
                  Do they use that to cover the soil pipe (the vertical plumbing pipe, "stack" usually a 3-inch or 2-inch or 1-1/2-inch plumbing pipe) to protect it from being covered with snow?
                  Since it is so easy to reach, I would snake down the 2-inch or 1-1/2 plumbing vent pipe right above the bathroom with the problem.
                    Assuming the toilet is next to the pedestal and the tub and pedestal drain into that toilet's soil stack.... the clog is between the pedestal and the toilet. Try running the snake through the pedestal drain a few times. You shouldn't have to go far just a few feet ought to do it.
                    It's also possible (but less likely) that the toilet and pedestal have their own waste stack in which case, if you're on the third floor could go all the way to the basement. I have no idea the layout.
                    Good luck to you sir!
                      solved , thanks!: bathtub is clogged, sink makes burping sound..
                      JJJAAAMMM: I have a drum trap in my bathroom and when I plunged it looked exactly like that. I am guessing all that crud is sediment from the trap. - thank you, jjjaaammm!
                      OLD1: Put a wet rag in the overflow while you are plunging the tub drain..Slam it with some authority..You might get wet but so what. - thank you old1!
                      dcman: Don't forget to get somebody to plug the drain and overflow on the lavatory.... - thank you dcman!
                      robert gift: Why ruin all the fun and surprise?
                      WEDNESDAY:
                      - thank you, robert gift!
                      geno gardner:
                      - thank you geno gardner!
                      thank you to you all very much for coming here to advise me! i'm sorry for this late response: i've been very busy.. thank you for your understanding.
                      good news: my problem has been solved!
                      i have been a very very stupid guy! i just didn't follow many great instructions given by plumbing teachers on yt.. i stupidly just .. inserted the snake in the drain and removed it, etc! that's why my bathtub remained clogged!
                      and then i went out 2-3 days ago to buy a new snake, a 25' rigid.. reading advices posted here.. i will never thank you to you guys for your advices & encouragements and knowing that there were people behind me, and i was not alone with my problems.. it really boosted my confidence! i am still new to plumbing, so i was very anxious & was in doubt that i could unclog this drain myself.. robergift: you were right, the 25' snake did help.. i used up to 24'! this time i ROTATED the snake, and it made the difference!
                      http://img17.imageshack.us/img17/3668/img0384ad.jpg
                      http://img14.imageshack.us/img14/4952/img0387f.jpg
                      thank you again to you all.. please forgive my bad english
                        To the pros: I am guessing he does not in fact have a drum trap if he was able to snake from the tub? It would have hit the trap and most likely stopped, no?
                        Just curious.
                          Seems logical....yes more than likely....but not necessarily...
                          Derek
