Cast Iron to ABS under slab
  • Cast Iron to ABS under slab
    Looking to get a detail of the proper way to connect CI to ABS under a slab.
    From what I've been able to look up: Use a full body wrap no-hub connector to join the CI to ABS. Bed the ABS in 6" of sand and deep enough to come up at least over the horizontal mid point as to minimize the deflection. Cover with dirt, no rock, then pour the slab. While of course maintaining at a minimum the 1/4" per foot drain slope.
    Sound right? Missing any details?
    Re: Cast Iron to ABS under slab
    How far under the slab...if within a foot...I put back 3/4" clean rock to about 4" below the exsisting floor then pour back..otherwise sounds good to me, the way you described...
    Derek
      It's within a foot of the bottom of the slab. I pulled up the last four feet before the main riser.
        Fernco coupling with a shear ring
          on piping larger than 2'' it has to be a rated transition band for cast to plastic. 2'' and smaller, a normal no hub band is acceptable under the upc.
          no all rubber bands. they have to have a shear ring or a mechanical joint coupling.
          outside the structure of the home, they can be all rubber.
            Hey Rick, this is for 3".... do they make it easy to know it's appropriately rated? Any ANSI number to look for?
              if in doubt go to a supply house like you would to get a buck transformer. breid..............
                Fair enough.....
                  a cp33 is the transition band for 3'' cast to 3'' plastic.
