Can a one-way sewer valve be installed in existing house?
  • Can a one-way sewer valve be installed in existing house?
    Or, if a back-up is anticipated due to heavy rains, can one plug their basement drain with a test plug? (Like what I used to fill my PVC system with water to the top of the roof vento pass inspection.)
    I do not know it they have a basement bathroom.
    Thank you.
    Re: Can a one-way sewer valve be installed in existing house?
    Thank you.
    Yes you can do either...is the city getting overloaded in the rains and then backing up momentary in your basement? Lots of basements here with bathrooms....
    Derek
      A fellow volunteer firefighter acquaintence in Pennsylvania. Sounds like he has had this problem before after heavy rains.
        Yes you can do that.
        My town got annihilated by 2 major storms last year 1 month apart. Many basements had 4-5' of standing water for about 12-14 hours.
        If you have an older home, the sewer will be subjected to some minor backpressure and if the sewer is clay tile ir even cast iron (sometimes) that can be devastating to the joints.
        There is a lot of discussion of the various forms of "flood control" on the forum in prior threads.
          You need one of these installed.
          http://www.backwater-valves.com/
          Full port, normally open backwater valve.
            Would be nice if they could make it a combination valve and basement drain and cleanout.
              Oh it can be done, will most likely be putting it in the bsaement though, unless you want to dig it up in the yard. Which would most likely put it in the 8 foot range, if not 15ish...
              Could see it going in the floor of the basement pretty easily. Unless there is some code against this that I am not aware of. Anyone know?
                If protecting the basement is the main goal then a B/W valve in the floor is great and somewhat easy. But if there are other drains left unprotected that are downstream of where the valve is placed they will not be protected. For instance if there is a daylight basement door access with stairs that has a drain and it is downstream of the new valve then sewage or rains would come up on the stairs and possibly flood the basement anyways. Then an outside valve offers better protection, but another problem could arise say there are downspouts tied into the line and you use an outside B/W valve and it inacts because of sewer back up the rain pouring into the downspouts will now come up in your basement. So one must be careful when installing a b/w valve, a sewer camera may be your best friend in this instance.
                Seattle Drain Service
                  Originally posted by Cuda View Post
                  ... but another problem could arise say there are downspouts tied into the line and you use an outside B/W valve and it inacts because of sewer back up the rain pouring into the downspouts will now come up in your basement. ....
                  I assumed only one basement drain and placing it downstream of that. Or inflating a plug in the drain so nothing can come out of it.
                  I did not know anyone drained downspouts into the city sewer system.
                  Would heavy rains not overload the sewage treatment plant and ruin digestion by over-diluting the liquor?
                    They only do this in areas where the storm water and waste are combined. I don't believe you are in one of those areas.
                    I would consider an adapt-a-valve with a test gate. You would have to do it manually but it would protect you. They are manufactured in the IPEX factory to really high standards. The only reason you don't see more of them is due to poor marketing.
                      Denver is one place where they probably could get away withat.
                      But what a horrible idea to send rainwater into the sanitary sewer system.
                      If his clothes washer and utility sink are in the basement, as most in Pennsylvania,re, that could be a problem requiring a two more plugs.
                      The problem with manual operation is that one would probably be away when they needed to close it.
                        Your problems with a backwater valve is they are illegal for fixtures with flood rims above the upstream manhole. In addition, they can and do need maintenance to prevent stoppages. The test gate would be no different than the test plug you asked about.
                          The plug would work if you were home .I would install a backwater valve with a cleanout down stream before exiting the house
                          I am sure they have ways of controlling the incoming water
                          Sounds like he is
                          And the fact that you have to "manually" operate it which again means you have to be there to do it ..Not sure I'm liking that idea althopugh I have never seen / installed one
                            How? Where can they store and slowly release such a huge volume of water?
                              They have giant sediment basins and tanks but the storage is limited. When the system is over-burdened, they have outfall pipes that dump it into the river. The EPA is finally starting to fine municipalities for overflows.
                              About 90% of the almost 800 combined sewer systems are east of the Missouri River. Then there are two in California and maybe another 40 between Oregon and Washington. Colorado does not have any CSO.
