Sump Pump Weep Hole Location
  • Sump Pump Weep Hole Location
    Ok, everywhere I look it tells me to make sure I drill a weep hole between the sump pump discharge and the check valve (usually 1/8"), but I see many discrepancies about if it should be above or below the water level.
    My pump is about 6" below the water level 365 days a year (high water table). The check valve is about 4' above the water level. Obviously the weep hole must be within the sump or it would spray all over the place when the pump is in operation.
    What's the consensus - weep hole above the water level, below the water level, or it doesn't matter? Thanks.
    Re: Sump Pump Weep Hole Location
    The hole is 3/16", not 1/8" and it is supposed to be drilled within 6" of the discharge port of the pump.
    It's to prevent air lock when the pump can overpump the pit, leaving air in the impeller chamber before leading to the next cycle.
    All submersible pumps are under this recommendation so the pump will perform, removing all possibilities of an impeller spinning in a bubble of air, not having the force to push open the check valve and remove the water.
    You want it below the level of water where the point of which the switch engages to come on. Drill the hole in a angle 45 degrees downward and point the hole away from the pump.
    When you hear the pump shut off, you'll hear this cavity of water fill inside the pit through that hole, flooding the impeller area to provide the correct function for the next cycle.
      I usually have my check valve with in a foot of the pump...I don't think there is a set level other than to be container within your pit...why is the check 4 foot high?
      Derek
        There can be numerous reasons, I sometimes will put them outside the pit if the existing was the same in design. But, I'd rather one leak/break in the pit, not out.
        On the hose clamp/rubber boot type, I've yet to find a clamp that the worm gear and band is 100% GOOD stainless, the kind you can say it will last indefinitely without rust or corrosion a part of the equation.
        I still do not trust those compression type with the rubber ferrule and nut; seen a lot of them where the nut loosened or cracked, arriving at a home with water shooting up to the ceiling.
          Well yea, on a septic pump system we usually put a second check in the ground horizontal outside the pit...Its all a kinda of catch with those bands and with the dresser style...sweet!!
          Derek
            Dunbar is absolutely right with his first post. I built my own house. My sump pump was a submersible and I fogot to do this. It air locked ! I never forgot again. LOL
            The Plumber/Firefighter
              Go with a LARGE Pit ,or You'll be cycling to often. Using P.T. Plywood two screen door handles, fender washers and 2" ridgid foam insulation Make a quiet cover. 18" dia cans suck, go 30"
              plastic culvert. Good luck
                Tool I'm the only guy using these in my area. Got 4 of them waiting for me at the supply house monday to purchase. It's the best switch I've used in applications relating to sump pumps, as I can adjust the leve at where it pulls the largest amount of water from the water table.
                It's basically the same design as a pedestal sump pump in regards to the switch. I would not recommend a pedestal sump pump though.
                I tell customers that it will be the last pump they install in their pit knowing the switch normally is the only true wearable part that makes them nonfunctional.
                  Thanks Dunbar. I have a customer with a serious seasonal high water problem. Full basement, drain tile sump pit. and a Hydromatic submersible pump. She needs the best EXPENSIVE PUMP, and in My opinion has it. I did the custom soundproof cover , i mentioned. I also set it to pump when the pit was at least 3/4 full. It cut all the constant cycling that kept Her up nights! The pump pros. had it cycling every tea cup entry amount. Poor Gal! Think She wants to Marry Me now !
                    [ATTACH]13547[/ATTACH]
                    I take it you are using the Zoeller Non-automatic pumps with those? If I could get my supply house to keep those in stock that is what I'd be using too.
                    To me, Hydromatic and Zoeller are pretty equal in PUMP quality. Hydromatic switches are just easier to replace. I actually like the Hydromatics that have float switches a lot. The diaphragm switches are awful! It's all Ford/Chevy talk IMO. I just wish the non-automatic Zoellers were easier to come by. I prefer the Zoeller design over the hydromatic
                    Oh, and speaking of pedestal pumps....when I sell one of these pumps, I guarantee that it's the last pump that they will ever buy (the manufacturer guarantees it for 10 years)
                    http://tramcopump.com/ResidentialDetails.cfm?ProdID=28
                    I have customers with these pumps installed that are 35+ years old. I replaced a switch on one that was over 50 years old last year! The old electrode switch had gone bad, so I put on a standard Square-D lever switch with float ball.
                      Thanks for the info. Why do I think most plumbers in Your area are
                      sump pump savy. Tanks Tool
                        The motor appears to be above ground on this model? How loud is it? I have a small center city basement and I would think it would be a bit loud.
                        But it sounds like it would outlast others as the pump is away from the water.
                        Regards,
                        K. Nezz
                          Hi Knezz and others,
                          Sitting here on a tiny island off the East coast of Newfoundland in Canada trying to setup a new sump pump properly. It is a warm day for winter but it is not the ideal weather to be dealing with pumps and water outside (actually a dugout under the house). Been struggling as this is not my area of expertise, to say the least.
                          Main problem was with the float ball sticking on a new pedestal sump pump I installed. The new pump is about 1/2" wider than the previous pedestal pump and the float ball sticks on the wall of the sump pit where the pump sits. Tried this and that, thought about other options without any luck. Then reading through this post it occurred to me the level of the water at which the pump switches on is not that important in my situation. (I have large concrete basin that holds 100 or more gallons before it would overflow.) The insight which saves me a lot of work is simply to adjust the height of the float ball so that it is higher than the wall of the sump pit. Yes, there will be a couple of inches of water sitting in the concrete basin but this does no harm. Went underneath the house, adjusted the float ball height and voila, the problem is solved.
                          I am grateful that people like yourselves take time to post ideas, comments and of course solutions. There may be issues with some parts of the Internet but forums like this a God-send. (To top it off, while I was writing this post, the sump pump kicked in for the first time after setting the new float ball height.
                          BobC
                          PS: I originally came to confirm the correct size for a check valve weep hole. Funny how things work out sometimes. I live full time in Germany, have a little vacation house in Newfoundland and have been helped by folks from Maryland, Kentucky and California.
