Super Vee 1/4" reverse auger ?????????????
  • Super Vee 1/4" reverse auger ?????????????
    Have a broken 1/4" cable on My super vee top gun. Good time to do the reverse auger Rick special. Never done one, could use some advise. Should I keep the bulb size same as came on the cable ? [ It was fixed ] I imagine this would be great for shower traps and tub overflow access. thanks in advance, Tool
    Re: Super Vee 1/4" reverse auger ?????????????
    Well you all ready have 99.9999 percent of the work done by having a broken cable.....now just call it a reverse auger and your all done
      Won't grab much hair though, as is !
        F the broken end up a bit.Stretch it out some
          Re: Super Veer 1/4" reverse auger ?????????????
          tool, the trick with the reverse auger really only applies to the sectional cables.
          a 1/4'' cable with no end is still a 1/4'' with a bent end.
          the reverse comes into play with the sectional and creates a corkscrew effect.
          bend a slight offset in the last 2'' and hope for the best.
          the sectional is the true hair grabber.
            BUMMER I'll call colman Mon
