Locating E.Quake valve in Customers Garage
  • Locating E.Quake valve in Customers Garage
    See any problems with this? Not enough room outside at Meter. Tanks Tool
    Re: Locating E.Quake valve in Customers Garage
    I don't know what exactly "or other approved location" means, but reading the "exception" kind of tells me that unless it's approved to be installed anywhere other than the exterior then it's a no-no.
    Ideal Plumbing
      tool, keep in mind, anything installed prior to the seismic valve is not protected. typically the only piping not required to be protected is exterior piping. very typical to outdoor pool piping.
      garage piping should be protected prior to entering the garage/ structure.
        Thanks, This is right after meter and before anything .
          I would imagine having it on the exterior would prevent a gas leak in the event that a quake caused enough movement of the garage wall that the pipe is penetrating.
          Ideal Plumbing
            I will keep the valves outside always!
