new tank hitting large water pipe
  • new tank hitting large water pipe
    I have a new toilet I want to install but water supply line comes out of the wall behind the tank. The pipe coming out of the wall is probably 1 inch and there is a bushing to get it to 1/2 inch copper. It's an old house with plaster walls and galvanised steel pipes. I'm thinking I need to cut into the wall and make the transition from 1 inch to 1/2 inch inside the wall. Then I would have to re-tile part of the wall.
    I took a picture but not sure if it uploaded so here is a link.
    https://picasaweb.google.com/1028761...eat=directlink
    Re: new tank hitting large water pipe
    Contact Clipper City Plumber.
      If you changed the nipple coming out of the wall to a shorter one would that help?
        Do you think I can get the nipple out without cutting out part of the wall?
        I'm also concerned how to check for a leak inside the wall if I put a shorter nipple in.
        I don't think I'll be able to see the pipe inside the wall where the nipple will screw in.
        I wonder if I could put a shorter nipple and bushing in and then a 1/2 90 degree copper fitting.
          the original install was a flushometer toilet.
          you could get a commercial 1.6gpf bowl and a sloan valve. this would be the best flusher in the house.
            Rick,
            The house was built in 1920. Do you know if that size water supply pipe was normal back then?
            I didn't think about getting a commercial toilet but that might be a good idea.
              What's on the back side of the wall?
                There's a half bath on the other side of the wall.
                I think directly behind the toilet is where the other toilet is.
                They probably share the same vertical waste line.
                  Open the wall to make the correction and replace that pink tile. You never liked it anyway and you can tell your wife we said it had to go!
                    /5. what year and all. post pictures. still don't have one. now i will spend the few days looking. breid...................
                      Oh no ..not again..Remember the last guy that just wanted to repair his sloan valve..Thinks he's done yet
                        My self , I'd just cut it off in the basement ,and install new plumbing in the proper place! Eze for Me, no tile damage !
                          Back to back bathrooms. I don't think it will be that easy! Open the wall and be done with it. While in there replace all of it.
                            I recommend this option, I can come down there and help you
                              And there he is..
