Why is the T and P valve blowing?
  • Why is the T and P valve blowing?
    I have a job for tomorrow where the t and p relief valve has blown water out in the morning either during or after water use.....the pressure going at the service bib is only 45 pounds......the water heater was installed about 3 years ago but was never lit until last week.....I found out the temp. dial was all the way up, the superintendent of the job turned it down before i got there....Do you think it was the temp being too high? Im wondering if I need to replace the thermocoupler....it is a bradford white 40 gallon....im going there in the morning for a couple hours so i should be able too see if the valve opens again....any ideas are appreciated...thanks
    Re: Why is the T and P valve blowing?
      Maybe just a bad T&P
      Got a thermometer,see what the temp of the heater is
        spend $60.00 for an expansion tank. Code in Wash. state,they got it right
          I am with JC on this post
            If it was me I would replace the thermo couple and the burner assembly but if you're going to do that you may as well replace the flu piping and the gas valve too because you just never know!
            NO NO NO NO I'M JUST KIDDING!!!!!!!!!!! If the t-stat was turned all the way up then that's your problem. Replace the t&p valve, set the water heater to the correct temperature. It has NOTHING to do with the thermo couple.
              Thanks everybody....Ironranger, your the man, thats exactly what I did...I ll let you guys know if i have another problem with it....so far, so good though...
