4" cast Iron, at hub to ABS plastic?
    Re: 4" cast Iron, at hub to ABS plastic?
    Originally posted by OLD1 View Post
    A service weight gasket..Why would you even bother with anything else
    I used to do it more years ago. The verticals are easy and I don't mind doing it. It does not take that long. I still admire some of the old ways of plumbing and admire the boys who did every joint that way. It also works great. It also depends if i have the gasket and if i feel like going to the store. I usually have them though. It just depends on alot of things. The horizontals are a bit harder and take some more time.
    The Plumber/Firefighter
      I also carry an assortment of cast iron flanges for service work. I will pour one of those in a minute. My partner thinks it's funny that I still want to do this .
        The one I poured in the pic took 10 minutes(maybe) from start to finish once I cleaned the old hub out. No big deal.
          Yes, the verticals are easy . Not much more difference in time after beveling the pipe, fighting getting the pipe in the gasket and getting turkey snot all over you. Lube - that's what the old timer who taught me called it. LOL
            Go to a plumbing supply house. Proflex is a rubber booted stainless steel band, You'll read on the band the match up C.I to plastic.
            So EZ a cave man can do it !
              You can also buy it to match up with DWV copper .
                I don't think it's funny to do .It's often the right thing to do ..Older home w/cast iron flange already..No problem, especially when there is nothing to bolt the flange down to.. the cast iron is a life saver..
                Sometime it takes a little effort to do things right..
                • #23
                  I agree 100 percent . I always carry them just in case and they are solid like you said.
                  • #24
                    Awhile back a had to install a cast iron flange..I had a 3" flange but it needed to be about 1 1/2" ..Took out the ol' angle grinder with the cut off blade and whammo ..pretty slick..I love that grinder
                    • #25
                      I know what you mean there, it's sometimes to long or to short . Years ago no grinder or cast iron sawzaw blades. I am not sure why i did not have them, i dont think most people did . I tried to think of everything to make the adjustments. I would even try the old crescent wrench snap all the way around. Desperate times calls for desperate measures. I am sure I tried some other crazy things that I don't remember.
                      • #26
                        Yeah my buddy called me recently to come over and bring my grinder to cut down some cast iron..I swear that thing will never leave my truck..slick as a whistle and the blades are cheap..I hate using snap cutters esp. on old cast iron..always seems to crumble or I get less than perfect cuts..Even if I can cut most of the way through then finish with a sawzall blade it beats cracked pipe..just my .02
                        • #27
                          I agree, the snap and the ratchet cutters were always a pain to use. When u cut CI in a muddy ditch many years ago I bet you wish you would have used the grinder or sawzaw instead of fighting with those things. I am like you with the grinder. I carry the Dewalt 18 volt cordless and the corded along with all different types of blades. I also now carry that multi max with an assortment of blades. Good for cutting grout, drywall, wood and plunge cuts. I have used that a few times as well.
                          • #28
                            Don't have a multi max YET...But I carry a dremel tool also
                            • #29
                              The dremel is nice and I think might even be better. U can set depths and I believe has many more accessories. Do you use it much ?
                              • #30
                                Are you going to watch the special tomorrow on dateline at 7 in reference to dishonesty of contractors sometimes.
