Copper de-burring tool
  • Copper de-burring tool
    Do they make a hand tool to de-burr the inside of a cut section of copper tubing? And also simultaneously remove any raised ridge on the outside of the pipe.
    I have been using the pointed thing on the end of my tubing cutter but it seems there mus be a better way.
    Re: Copper de-burring tool
    On the rigid cutters if I did have to deburr a pipe I just use what's attached to the cutters. I have ran copper for many years and still do, I never have to deburr the copper, I just cut, clean, sweat and I am done.
    The Plumber/Firefighter
      Yes they do but the are bulky and a pain to use. I would deal with the occasional burr on the outside of the pipe as they happen but use a Rothenberger reaming tool on every joint. Reaming is required under every code and prevents velocity erosion and unwanted noise.
        Not that I'm aware of. A good mill file will take care of the external ridge.
          Here are the Ridgid Inner/Outer reamers.
            Fred's favorite
              Fred's favorite
              That's funny, as I posted the picture I was remembering that conversation.
                You guys are good. There are sharp people on this forum. I have to buy my wife a car in the next few weeks as her car the tranny blew and I am just going to donate . I almost want to give you guys the make and model of what she wants so you guys can firgure out the eaxact price i should pay so i dont get ripped. LOL I do apprecite all of you guys.
                  a good 1 wheel tubing cutter such as the ridgid #15 will prevent outside ridges and burrs. that's the purpose of the rollers. a 4 wheel cutter is not a cutter for fabb work. it leaves an inner and outer ridge.
                  i have a deburring tool that works on 1/2''-2'' copper that doesn't produce any scrap shards to fall into the pipe. it uses 2 little pin rollers that actually roll the copper back onto itself. also good for re-rounding soft copper.
                  i believe it's made by atlanta specialty co.
                    spyderco harpy c08s. breid.................
                      They do make what I call a pencil reamer,about 6"long with a replacable blade on the end,works on the inside of any size pipe.We get them at the supply house.
                      Steve in the trade since 73 doing new residential/Commercial work
                        Super reamer
                          google emt reamer. breid...................
                            Being a welder, and serious toolaholic gives Me a different take on many solutions. I chuck up in My 18 volt makita My step hole cutter.
                            It the ultimate reamer.
                              Not a bad idea....I'd imagine it would be easy to get carried away with that setup though lol.
                              Ideal Plumbing
