How far can a standard washing machine push the water to the drain?
  • How far can a standard washing machine push the water to the drain?
    I need to place a standard washing machine's water discharge about 12 feet from the sewer line [5 feet up to rafters, 7 feet across rafters (I plan on having at least 2 degrees downward angle to the sewer line) - I'm not counting the 2 feet down to the drain a gravity will handle that.
    Does that seem to be a potential problem?
    Regards,
    K. Nezz
    Re: How far can a standard washing machine push the water to the drain?
    I don't think that is possible. The pumps on the machine are not ment to push it that far.
    You can check with the manufacturer of the machine, but I think it won't work.
      Here's a start for You. Liberty makes a fiberglass catch basin ,guessing 18" diameter. Inside You'll have a 1/3 H.P pump. There will be a knock out on top for a 2" P.v.c. pipe to plumb this into one of Your drain lines.Washer dumps into this basin. You'll also want a check valve near the bottom of YourPVC riser. Contact Your local plumbing inspector for advice If You do this Your self. Most are very helpful.Ps You'll need to install a trap,also
        Here is what Toolaholic is talking about. Very common around here to discharge a washing machine into this, then it pumps the water into the sewer.
        http://www.libertypumps.com/Data/Sal...ure/404web.pdf
          Hang on now, didn't the post say 5' up and 12 horizontal? If so any washer will handle that.
            zz
            google is your friend. i googled my washer brand, picked out my model and clicked installation instructions. there was my answer. my guess is it will work for you. if you can guess my brand and model i will tell you the answer. lol. breid......................
              Re: zz
              Breid I think NHMaster is being sarcastic. At least I hope so. I never been a fan of plumbing a washing machine waste into an overhead sewer system even if you can properly trap and vent it. When people do plumb in a drain like that for a washing machine and the first time a city sewer backs up and their basement floods due to the sewerage spilling out from the washing machine drain hook up, they will blame everything else but the hacked in drain. Using a pump box will help prevent that type of flooding.
                N.H. Master, can you show a lil detail how You would plumb this! I just want to learn ,and it will help the poster also .
                I'm just stuck in the common stand pipe code, and haven't had My coffee Yet. Thanks tool,and a few more ,I'm guessing
                  Re: zz
                  That does make sense! My people skills class is at 8:00 pm tonight.it's at the old Knights of Columbus hall. Funny ALL Tradesman!
                      Thanks, would an inspector pass that on the 18" standpipe rule ? And He may be up close to the sub floor on a limited old basement .Just trying to learn !
                      Ps bucket isn't there for ART DECO, EITHER,ME THINKS!
                        not arond here. If you havean overhead sewer the washer must drain in to a pump.
                          knezz here You go Nice n clean $563.63 www.plumbingsupply.com/sumpboxsystem
                          We love pictures! good luck Tool
                            That also looks like illegal "s" trap.
                              You would be suprised what home owners come up with.
