is this new plan valid?
  • is this new plan valid?
    Please have a look at my new plan to see if it is valid.
    1. dot line means vent;
    2. solid line means drain;
    3. black line is existing pipes;
    4. red and blue line are new planned connection; The red line was connected to another main stack which doesn’t have any other connections from basement. I want to gain more space in basement bathroom so plan to move it.
    Question:
    Will the red line connection make the entire layout invalid?
    Is the blue line connection ok?
    thanks,
    Re: is this new plan valid?
    This may has a big different result:
      Terry said it was good. What more do you need?
        DWV design is a challenge. I like it. I wish I will be a plumber one day. If following change is valid, it will be a better solution to me. Any expert here can say something about my plans?
          Question:
          thanks,
          Why would the 1st floor "counter sink" have a "dry vent" extending from what your calling the basement?
            that vent is a vent only vent. it is also the basement floor drain AND basement toilet vent, I think. That is why it starts from basement and finally goes up to the attic.
              You crack Me up!
