New Bradford White Power Vent Water Heater - Which drain valve should I use.?
  • New Bradford White Power Vent Water Heater - Which drain valve should I use.?
    I've never seen the drain valve that came with the unit.
    Should I keep that (how does it work) or change it with this?
    Pros and cons please?
    Thanks for the help.
    Regards,
    K. Nezz
    Re: New Bradford White Power Vent Water Heater - Which drain valve should I use.?
    The one equipped with the Bradford white water heaters are ball valves, so in my humble opinion its best to stay with the stock one verses the one want to use.
      second that!!!
      Derek
        No information on the drain plug - I assume I would just open and close the screw to expel the water? Have they been proven pretty much leak free?
        Regards,
        K. Nezz
          rotate the screw 90 degrees to open, the same to close. and no issues yet, I have the same installed in my home.
            Thanks all ... case closed..
            Regards,
            K. Nezz
              Its a ball valve, they use the screw head instead of a handle for safety. To many kids come up to a water heater and turn the handle and get scalded.
