finding buried pvc lines
  • finding buried pvc lines
    Neighbor has many, some from an old well. Any ideas how to locate them? thanks.
    Re: finding buried pvc lines
    2 plastic straws, 2 bent coat hangers, metal type, about 20" in lenght, bent in the middle, stick the ends in the straws so they swivel, hold your arms at your sides, bent up at the elbows below youyr chest and walk slowly, when the hangers point to eachother, the line is pretty close to under you.
    Im having a hard time explaining it, but have done itbefore, pretty good results also.
    someone else might be able to put the instructions into be directions! Its called dowsing. I find the hangers in the straws work better instead of just holding the wire in your closed fist
    Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
      the microdrain will go through the 1.5'' pvc 90's pressure style.
      the camera will also go through 1'' pvc.
      then there is a nano cam that will fit 3/4'' pipe. not sure about the 90 sizing.
      they all have sonds that allow tracking.
      i once did 200' of 1.5'' pvc with 45's pressure style on a koi pond for a big wig mayor with my mini seesnake.
        We call it witching round these parts. And it's about as accurate as pissing on the ground and saying, your pipes right there, I see water.
          Pulse generator and a leak locator.
            Call an electrician. Tell him to install a new ground rod and I gaurantee he'll find it
              Don't listen to any of these self proclaimed plumbers
              If you want to find underground pipes, use this.
              IHI 15NX MINI EXCAVATOR | eBay
              They are 100% accurate and they have this unknown feature that is automatic. It is called the "autolocate"
              What it does is allows the machine to automatically locate buried lines you didn't even know existed!
              Just start digging, the machine will do the rest.
                Still called a shovel.
                  Bump
                  +1
                    100% Foolproof. Allthough.............sometimes I use an electricians fish tape and my Metrotec 810.
                      Have an 8 ton backhoe, i know
                        Im with thé shovel idea Better yet tell thé homeowner He Can save alot of money sell him your shovel and tell him point ?* and point b let him decide how to get there. Jjk sean
                          Sean, where does one get mini carharts for toddlers at? Looks like a little boss bout to do some work in those
                            A Good Friend of mine got them im not sure Where il ask him thou...stolen
                              Good I need some, my son in 6 months old and the perfect size to stuff off in a crawl hole!
