dripping sound from toto Legato
  • dripping sound from toto Legato
    Haven't been back yet but customer hears a dripping sound from tank! Will use dye to check flapper, and see if water adjust. is to hi on overflow tube. Any suggestions appreciated. Thanks Tool
    Re: dripping sound from toto Legato
    Originally posted by toolaholic View Post
    ... customer hears a dripping sound from tank! Will use dye to check flapper, and see if water adjust. is to hi on overflow tube. ...
    Could it be that as the tank water nears shut-off height, the valve slows to the point of filling the tank one-drop-at-a-time into the overflow tube?
    When it is doing that, I would shut off the STOP and see if it continues.
    Otherwise, it sounds like a leaking flapper or loose assembly parts - if that ever happens.
      No ,I've ajusted water to be 1/4" down on O.F. tube . It's not a big issue. no leaks
