coin opperated showers ?
  • coin opperated showers ?
    Any one install these or have any advise I got six showers, in a campground bathroom. Another plumber that bid on the job was going to use a central mixing valve and a series of solenoid valves when you put the money in your shower head comes on and its preset to a determined temperture ?, what do you guys think?
    Re: coin opperated showers ?
    i think the temperature should be user adjustable. the time is preset and typically you can add minutes to finish off.
    the timer controls a water solenoid valve to shut it off.
      I have a friend that had a mobile show company that went belly up during the downturn, but anyway, they used carwash timers that as Rick said controlled a solenoid on the water supplies. Used standard mixing valves for temp control.
        I need those in my house! Might keep the kids from hangin out in the shower all dang day!
          Just put a shutoff. On the hot line to the shower and don't close it just barely crack it....Jjk my step daughters eight already dealing with that... Think I might put a shower and hot water tank in my shop.
