Rigid pump doesn't always turn on
  • Rigid pump doesn't always turn on
    Sometimes water goes above my pump and my pump doesn't pump. If I shake it it will fire up and then work most of time.
    Any idea what is causing this?
    Re: Rigid pump doesn't always turn on
    Sounds like the float switch is getting stuck may be as simple as cleaning your pump and sump pit.
      That and it is a Ridgid pump.....sorry not best choice.....
      Derek
        is the switch that turns it on a mechanical float switch, or the solid state sensor type?
        the sensor type is notorious for intermittent operation. If it is that type, replace it with a float or replace the unit with one with a mechanical float.
        if it has a mechanical float switch, drain the pit and make sure there is enough room for the float to come up and turn the pump on w/o getting caught on something.
