American Standard - not so standard?
  • American Standard - not so standard?
    Got an American Standard fiberglass clawfoot tub (fairly new) but the drain and overflow that was attached.... is neither 1 1/4 or 1 1/2... it's somewhere between the two. I need a tee and a straight plus the PVC adapter... and with a chrome finish. Anyone seen this before?
    Re: American Standard - not so standard?
    You probably have 1 1/2 tubular pipe you may need a 1 1/2 trap adapter
      ...for some reason i'm getting a vision of the old 1&3/8ths size pipe.
        Yep I have and you need to head on over to a plumbing supply store for what you need. Cheeepo Deepot and Blowes won't have it.
          Sign of the Crab page 56
          Strom Plumbing Catalog - 2011 Edition
            Recommend any? Ferguson Plumbing Supply doesn't have a clue what it is.
              Too small for a 1 1/2 adapter..
                Every clawfoot I ever installed was 1-1/2" tubular on the drains. If that is not what you have, then why not get a new drain set that is of standard size?
                  I have a hard time swallowing a $300 tab to replace something I already have...
                    Originally posted by Paul GA View Post
                    Q. "With the old fashion style 1 3/8" o.d. bath tub drains, how do I adapt to my standard 1 1/2" threaded p-trap?"
                    A. We offer a 1 1/2" x 1 3/8" chrome slip joint nut along with a D style o-ring that will fit onto the 1 3/8" o.d. tubing. Simply order the slip joint nut and d-ring above which includes both the special reducing nut and the special o-ring.
                    plumbingsupply.com $15 shipped for two, $285 saved.
