faucet cartridges
  • faucet cartridges
    Is ceramic a good material for a faucet cartridge? I know plastic is cheap, is brass the 3rd option?
    Re: faucet cartridges
    ceramic is the best of the 3.
    most ceramic have a lifetime warranty. you just call the company for replacements.
      I would say ceramic....but here is old school thinking by both consumers and suppliers.....what would your response to be to people that bring up sand etching the ceramics?
      Derek
        Sand etching eh as money in jetting wore off on you dcman ...Jjk i think ceramic for sûre plus life time warranty as long as you have replacements shouldnt be a problem...i dont think...as long as your Not affraid to actually service * fixture instead of replacing it. Seanny
          ceramic happens to one of the longest lasting materials. the better jetter inserts are ceramic.
          unless they build it out of carbide or diamond, ceramic is very, very durable.
            That was very uncalled for!!! LOL.....Sand may not have been the right word...grit....maybe...or just hard water deposits? I guess what I am driving at is can ceramic be etched to start with? I live in a very rural community...we are about two years behind on plumbing technology and advances...And no, I repair faucets all the time....no problems...I don't know why one wouldn't repair over replace at least one time....
            Derek
              I come across just as many leaking cermic cartridges as I do ones with a seat and washer. ITs normal wear and tear.
                Wow...I thought that ceramic cartridge's where somewhat impervious to that kind of stuff...which I thought was supposed to be the "big" thing about why buy a ceramic disk faucet....which is why I asked in the first place...thanks!!
                Derek
                  It all depends on water quality, and how the faucet is used. Here is a picture of a shattered ceramic disc stem that was posted on PZ forums. I seen this happen a few times. In some cases it was a solder ball that flowed through and shattered it, others it was a small gravel that got in the plumbing from a main break. here is the link to the thread if you want to follow it. http://www.plumbingzone.com/f7/crush...r-stems-15588/
                    It all depends on water quality, and how the faucet is used. Here is a picture of a shattered ceramic disc stem that was posted on PZ forums. I seen this happen a few times. In some cases it was a solder ball that flowed through and shattered it, others it was a small gravel that got in the plumbing from a main break. here is the link to the thread if you want to follow it. Crushed Price Pfister ceramic shower stems - Plumbing Zone - Professional Plumbers Forum
                    Nice....couldn't see pics but that's okay....so in the end are you on board with ceramic faucets?
                    Derek
                      I like them in certain places. For example at a lab where they throttle the flow of the faucet, the ceramic works great.
                        Many ceramic disc carts are plastic body. So what you are really concerned with is the water-sealing material. Plastic, brass, are rarely seen. If not ceramic, then the sealing component is rubber. It might be compression...flat washer, rubber seat such as Delta, Valley, and many copy-cats, or o-rings and combos...pp, moen, etc. All have advantages and disadvantages. Even ceramics have rubber o-rings and rubber gasket body seals, which do fail.
