New House.
  • New House.
    Hello. This is my first time posting. I bought a house in July. Last night I was in bed and I heard water dripping. It seemed like it was coming from the wall which is at the head of the bed. On the other side of the wall is the exterior of the house. Is this a plumbing or roofing problem? If its a plumbing problem, what is it? If it helps I live in Canada and it has recently become colder (but not below freezing).
    Re: New House.
    This sounds like one where a picture would be worth a thousand words. If it's plumbing on an exterior wall, you might be looking for a hose bib issue. If there is no plumbing in the wall then that would have to come back to the roof.
      Re: New House.
      is there any plumbing that would go thorough that wall? (above or to the side, below the room) is the basement open to see the pipes? and where they run?
      If there is not any plumbing in the area, or is fed from a different place than in that wall, I would suspect it is from a different source as the plumbing,
      Just being in Canada I would doubt if there is much if any plumbing in the exterior walls, (as even here, in cold areas usually plumbing in the exterior walls is avoided if possible)
        Re: New House.
        Was it wet out, rain or drizzle? Gutters and a down spout near your bed? Very common complaint.
          Re: New House.
          what kind off heat do you have hot water baseboard somethimes makes noise like drpping
            Re: New House.
            Are you sure it's not your copper or ABS pipes expanding and contracting going through wooden studs and joists? They make a sound that is similar to water dripping.
              Re: New House.
              Infloor radiant HPEX can make those same noises depending on how it's installed.
                Re: New House.
                is there any plumbing that would go thorough that wall? (above or to the side, below the room) is the basement san diego propane open to see the pipes? and where they run?
                It sounds like you just may have a couple leakages in your roofing.. It's very rare that it would be your plumbing.
                  Re: New House.
                  when my old house would settle (I LIVE IN CANADA TOO) it would sometimes sound like a drip of water. Temp changes might be making the noise? Just a guess
