American Standard flush tower does not float on water.
  • American Standard flush tower does not float on water.
    New toilet.
    Larger tank outlet opening allows greater flush water bolus!
    As soon as neighbor takes hand offlush lever, the white plastic flush tower cylinder drops and closes.
    (I actually like that because I can make it use less water.)
    Flush tower has a funnel-like flare athe top. Rubber fill tube attaches to the flare.
    Inner vertical plastic mechanism with spring athe top and midway down looks like loose ratchet
    cams to catch on the tower cylinder.
    Have not even been able to disassemble it.
    Anyone know how this POC isupposed to work?
    Thank you.
    Re: American Standard flush tower does not float on water.
    if it's the one i'm thinking of, they had issues and will send you a replacment that is an oversized douglas flush valve/ flapper style.
    post a photo.
      post a photo.
      Thank you.
      I'll contact AS.
      I have no ability to post photos.
        http://www.americanstandard-us.com/a...r/472D598A.pdf
          THAT'S IT! Thank you Mark.
          Now I knowhato expect.
          I contacted AS and they are sending the replacement valve. Their flush tower never worked, even the firstime.
            Pretty pathetic design..Sucks even worse if you supply the toilet and have to go and replace the valve for FREE..I never buy toilets with the tower piece of junk design.Every time I install one for a customer I know what's coming next..
              Can you send AS a bill for the return visit?
              Anyone know how it wasupposed to work?
                To get a "water sense" label or qualify for any rebates, the design of a toilet has to be such that it is NOT POSSIBLE to flush more water by holding down the handle.
                Better get used to it, because today's 1.6 gallons will be 1.28 gallons....2012 in CA, and a year or so later in the rest of the country.
                  Hey let's pick an arbitrary number say 20% less than 1.6 gpm and make everyone try to move waste with that throughout the entire nation without causing problems.
                  Lord help us all !!
                    Originally posted by Robert Gift View Post
                    New toilet.
                    Thank you.
                    Sure sounds like an original champion toilet. Those flush valves were an astounding feat of some manager directing design engineers to operate at the lunatic fringe.
